To grease or not to grease (hitch ball)?
Postby les45 » Sun May 06, 2018 1:03 pm
I have an older Atwood style coupler on my pop-up project and it is hard to get on or off the ball unless it is lined up perfectly. The coupler is in excellent condition with no rust and I have lubed all the moving parts and sprayed the inside of the ball area with graphite. The locking collar is smooth with no roughness that would cause it to snag on the ball. Apparently there are two schools of thought on greasing the ball itself (yea and nay). I think the nays are mostly concerned with dirt collecting on the ball and causing wear on the ball when towing. I don't use the hitch that often and the receiver stays on a shelf unless I am actually towing. The ball is like new with the chrome still smooth and shiny. Anyone have any experience with this style of coupler and is it just the "nature of the beast" to be a little difficult in getting on and off?
les45
Images: 596
Re: To grease or not to grease (hitch ball)?
Postby steve cowan » Sun May 06, 2018 1:17 pm
I smear a little grease on mine before hooking up but wipe it off after unhitching.
steve cowan
Images: 120
Postby greygoos » Sun May 06, 2018 3:33 pm
Is there an adjustment nut inside the hitch?
greygoos
Postby les45 » Sun May 06, 2018 3:47 pm
greygoos wrote:Is there an adjustment nut inside the hitch?
There is no adjustment on this older style. The pivot arm on the top simply swings the locking collar forward to wrap around the ball and then the arm drops down with two teeth that drop into slots to keep the release mechanism from operating until it is lifted again. This type also has a hole to install a lock to keep the pivot arm from being accidentally disengaged very similar to the new style couplers.
les45
Images: 596
Postby Bill n Robi » Sun May 06, 2018 6:49 pm
I put some lithium on mine. Carry some cheap plastic bags to cover it once I am on site and setting up so I don't mess up the clothes. If staying for a few days, I wipe it off and recoat it. They sell a ball cover that pushes on but every review says they are crap.
2015 T@G Max
2015 Toyota Tacoma TRD Sport 4 Door Short Bed
Bill n Robi
Postby rkanz » Mon May 07, 2018 10:32 pm
This stuffs works really well. Lithium grease with Teflon.
https://www.amazon.com/Finish-Line-Prem ... B01G5VFCEQ
rkanz
Postby Andrew Herrick » Wed May 09, 2018 1:29 am
Either grease the ball ... or shell out for a stainless steel one :P
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Postby swoody126 » Wed May 09, 2018 6:50 am
rather than play the WHAT IF GAME try it both ways on your next outing and decide for yourself
if a film of litheum grease makes you happy just figure out how you will avoid the residue(cover/wipe off)
sw
swoody126
