Axle/hub supplier for a 6 x 135 hub bolt pattern. Ya, I hope to match to my F150 wheels...
Research so far is putting me all over the place and once on a site find out they don't have... Have a goto supplier you use?
John61CT wrote:Fancy stuff, etrailer.com, great outfit.
Bog standard leaf setups, ask around locally.
John61CT wrote:Hence spacer / adapters
not ideal, but allowing fewer spares to be carried, priceless. . .
gudmund wrote:for years there was 'one' 6 lug set-up and that was what GM had used since the mid thirtys - Even Toyota & Datsun/Nissan up until just a few years ago had also used it for years, along with the trailer industry (which they seem to be still using today - but - today GM is not even using that same "original" 6-lug set-up except on the Silverado. I see Ford-Toyota and others 'all' using 6-lug wheels now also. but they each have their own lug spacing distance between studs. (Even the 'today' Chev Colorado has a different size spacing than the Silverado today - even the first gen of the Colorado (2004-12) used the same lug spacing as the Silverado, but they wouldn't fit on the Colorado being the Colorado uses a larger center hole in it's wheel than the Silverado = now the 'today' Colorado ('15 on) has a smaller stud diameter pattern than the old being it is now metric sized. Almost all of the company's today maybe be using a 6 lug wheel, but they all are of a different sized lug pattern between them................
for Timbren axle-less, yes
Yes well, the topic at hand is trailers, and allowing use of the same wheels as used on the TV.RJ Howell wrote: Might be okay on a trailer, yet never on a drive wheel
