gudmund wrote:Timbren is seen being used a-lot with the 'off-road' teardrop trailers = seems to be a bit of "overkill" for the 'paved' road crowd. It does seems to be a good 'tryed/trued' system set-up 'but' also just a little costly $$$ when comparted to others (just my opinion.....)
western traveler wrote:I am looking at that option as well. Two miles of dirt road to the nearest pavement and I anticipate seeing many gravel roads in my travels. Curious if disc brakes are the norm on them or an option. Also can the rubber pads be replaced?
tony.latham wrote:There's a member here known as Capn Telescope... You might search here and see what you come up with.
kludge wrote:tony.latham wrote:There's a member here known as Capn Telescope... You might search here and see what you come up with.
thank you
Happy Fun Ball wrote:
Can you update what you find? I was also planning on using these and my trailer is probably going to be a bit heavy. I can definitely see these eating tires if they are overloaded or poorly aligned.
