Question on frame dimensions
Postby TxKayaker » Sat Sep 10, 2022 6:04 pm
Hello I am new here. I have done a little searching but havent seem to found anything on the info I am looking for.
I am going to build my frame. I am wanting a 5x10 trailer. The questions that I have are what dimensions do I need to build the frame to be able to get a queen size mattress inside? I see that a queen size mattress is 60" wide. So would I need to add a few inches to the trailer frame width to put the walls on? Like 62 or 63 inches? Or if i made the frame to exactly 60 inches and put the walls up with say 1/8in or 1/4in skin on both sides with a 3/4 core will the mattress fit? Thank you in advance.
TxKayaker
Re: Question on frame dimensions
Postby tony.latham » Sat Sep 10, 2022 7:19 pm
A queen fits fine inside our 60" (exterior) cabin. Inside it's 57-3/4" wide.
I rely heavily on Baltic birch plywood during a build and it comes in 60" widths.
Postby halfdome, Danny » Sat Sep 10, 2022 7:36 pm
Welcome to the forum.
There a lot of variables to consider.
What materials will you be using as a finish outer covering?
Aluminum can limit the exteriors final dimension.
Our TD is 60" x 120" and the walls overhang the chassis to hide it with 3/4 space in between.
The rear of the teardrop overhangs the chassis by 6" for the roll pans.
Our custom mattress is 58 1/4 x 80 ".
You need some wiggle room between the chassis and teardrop box to square things up and to run highway lights etc.
You might look into buying Tony's book to give you insight before ordering materials or look around at build topics to gather a plan.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby TxKayaker » Sat Sep 10, 2022 7:44 pm
tony.latham wrote:A queen fits fine inside our 60" (exterior) cabin. Inside it's 57-3/4" wide.
Does your walls sit flush with the outside edge of your frame or do your walls come down over your frame to hide it?
Yeah i was looking at some of that 5ft wide birch plywood.
TxKayaker
Postby TxKayaker » Sat Sep 10, 2022 7:52 pm
halfdome, Danny wrote:Welcome to the forum.
:D Danny
So your frame is exactly 60" wide and you had to get a custom cut mattress to fit in your camper?
I was wanting my exterior sheathing hang over the frame and hide it and have about a 1/8in gap between the 1/8" or 1/4" exterior sheathing and the frame. I havent made up my mind on the outer covering if it was going to be aluminum or filon. It depends what i can find in the size i would need because if i buld the frame to 60 inches and then the walls hang over then i would need something a little wider that 60" to cover the top.
TxKayaker
Postby halfdome, Danny » Sat Sep 10, 2022 8:34 pm
My chassis is 57 1/2" wide x 96" to the tongue "Y" which when added totals more than 12 1/2 feet.
Remember it's 6" short at the rear to accommodate the roll pans.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby TxKayaker » Thu Sep 15, 2022 6:47 am
halfdome, Danny wrote: My chassis is 57 1/2" wide x 96" to the tongue "Y" which when added totals more than 12 1/2 feet.
:D Danny
Oh ok. Thank you!
TxKayaker
Postby tony.latham » Thu Sep 15, 2022 9:50 am
I'm an exposed frame kinda guy... 8)
Postby GTS225 » Thu Sep 15, 2022 10:08 am
Just as an FYI comment;
For those of you that might not know......a "queen" mattress is dependent on whether it's for a residence or an RV/camper. RV queen mattresses are slightly narrower and shorter than a residential 60" queen mattress.
Just sayin'.....Roger
GTS225
Postby twisted lines » Thu Sep 15, 2022 12:36 pm
halfdome, Danny wrote:Our TD is 60" x 120" and the walls overhang the chassis to hide it with 3/4 space in between.
I found the answer !
One day you may find a old fat guy sleeping under that trailer :thinking:
Racking up; And Rapin foam
twisted lines
Postby Tom&Shelly » Thu Sep 15, 2022 2:31 pm
Then, there are those of us who are paranoid about getting hit
168706 168928
We were, in fact, originally going to have the walls come down over the frame, but this seemed easier. We didn't change the height, but could have gotten another three inches from the 4x8 plywood.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2023
Postby Onajourney » Thu Sep 15, 2022 3:47 pm
My frame is 60" wide and my interior is 56". I can squeeze the Milliard Tri-Folding Memory Foam Foldable Memory Foam Mattress with Washable Cover, Queen Size (78"x58"x6") . It's $269 on Amazon
https://www.amazon.com/Milliard-Tri-fol ... to_dp&th=1
Onajourney
Images: 181
