mgordon wrote:Hello All
Its my first post I stumbled into this, I was looking at t@b trailers and found this, now Im going to build one. Right now Im thinking a generic benroy, is a 41/2 by 8 ft good I think it can take 1300 lbs. Ive seen alot of red trailers and HF. I am in edmonton, alberta and looking for a good canadian trailer supplier rather than build one (which I can do) but ideally like to buy one for this one less headaches. I ll keep you informed throught my many requests
Thanks in advance
Matt
mgordon wrote:I found this one at canadian tire now on sale its payload capacity is 1255lbs and has 8 inch wheels(which I will change) cost $400.00 Will this do the trick?
matt
Thanks for hello PaulC. I think I should be okay in the question department I have alot of them
mgordon wrote:Thanks for the reply steve, your photos did not post so I cant see what you were showing.
What would be the "ideal" trailer for a generic benroy a far as spec
matt
Miriam C. wrote:Mgordon,
The generic Benroy is made on a harbor freight 4x8 folding trailer. I don't think it is the little one. They have two and now carry a 5x8.
If you go to the Harbor Freight web site it gives the details including what it is made of. I would pull it up but the is being slow tonight.
Good luck with the build.
Miriam
