greg55 wrote:The floor will be framed with1.5 x1.5 covered with 1/2" plywood.
Nitetimes wrote:greg55 wrote:The floor will be framed with1.5 x1.5 covered with 1/2" plywood.
If you want to dump a little excess weight lose the floor framing, there's no reason you can't just screw the ply to the frame and build from there. Deck screws work quite well for that.
greg55 wrote:my tounge is 2x2x3/16.Does the extra thickness make it much stronger?
Melvin wrote:Nitetimes wrote:greg55 wrote:The floor will be framed with1.5 x1.5 covered with 1/2" plywood.
Wafer Teks (or plyteks) are a bit cheaper than that and are designed to attach plywood to steel. You can get them in all sorts of lengths to match with your needs.
