by doug hodder » Sat Jul 01, 2006 10:46 pm
Dave...an idea might be to buy a used chop saw (beater) in a garage sale, stick on an abrasive blade for steel...I built my first tear like that...pretty much used up the saw however, but I was cutting 2x2 x1/8" tubing and channel, it pooped out on a piece of 1/4" x 3" strap...there's no problem doing it like you are, but a chop saw gives you better control on the angle and vertical....better fit up for the weld...and if you glaze the blade, iron turns cherry red, but no cutting....clean up the blade with a piece of a brick...you have to knock off the glazed edge....just what I've experienced, others may have varying experiences....got a Harbor Freight chop saw for #2...but get a good blade, the Eastern Block blades are crap...lots of wobble in mine Doug
