AngiB mentioned several of the advantages.
angib wrote:Several things to note from the
trailer's product manual:
- The bed appears to be 95" long by 57-1/2" wide - so no cutting is required to overhang the sides over the frame.
- The side rails are in one piece - so no sacrificing a cross member to join them together.
- The leaf spring has separate front and back brackets that are bolted to the frame - moving the axle position will be child's play.
- The illustration shows 5 lug nuts - so it may be easy to change wheels for those guys whose macho factor can't take being seen with 12" wheels.......
I have a few more:
-A-frame tongue for strength when doing bad things like backing up a curb while turned (I have trouble hitting my driveway).
-2" coupler instead of 1-7/8" which works better for those with other 2" trailers.
-One piece lengthwise rails (already mentioned by Angi) mean stiffer for less weight than two-piece.
-Frame is C-Channel as shown in the instructions:
