by Nitetimes » Mon Jul 17, 2006 11:15 am
I think that's gonna be
Expensive but otherwise I see no reason it won't work if that's what you really want. I am not a big fan of aluminum frames, too much drilling and bolting to attach all the steel parts that normally get welded on. Generally the weight savings is not enough to justify the cost difference if you build it as strong as steel is in much thinner material. Then again if ya already have the material or access to it cheap ya might as well use it. Do what you wanna not what someone else tells you to do.
BTW - as far as the frame layout goes, it looks fine!
Rich
- Thomas Jefferson -
