CAD tutorial
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby angib » Mon Oct 11, 2004 5:16 pm
Today's Top Tip - Fit a wall on the left side, otherwise everything will fall out on the road...
mikeschn wrote: Oh, and for the hatch... subtract out a block where the hatch is going to be, and then build a hatch!
Can't you be a bit more cunning? For example:
-copy the body off to one side
-create a block where the hatch will be
-copy the block off to one side
-subtract the block from the body to make the hatch cut-out
-use an intersection between the body copy and the block copy to make a hatch
-move or copy the hatch back to its position in the body
Make sense?
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Mon Oct 11, 2004 5:25 pm
Andrew,
Sounds like you're a natural born solid modeler... just use separate layers instead of moving block and bodies off to the side, and it'll be perfect!!!
So can we expect some wrl files from you soon?
Images: 471
Postby mikeschn » Mon Oct 11, 2004 6:57 pm
Brian,
I played with your file for a few minutes... I put a piece of glass on the left side so you wouldn't lose the contents of your trailer... per Andrew's suggestion...
I also stuck the weekender cabinets in there... They don't work well with the size and shape of your teardrop, but it gives you something to look at!
Go go ahead and give it a whirl (right Bev?) :lol:
http://www.mikenchell.com/images/brian.wrl
P.S. I made the door on the street side bigger too... it's now 30"x48".
Images: 471
Postby BoilermakerFan » Mon Oct 11, 2004 7:11 pm
Thanks Andrew. :roll:
I didn't put the street side wall on it to show off the Burl Maple interior!
I'll be reconstructing the doors later. Adding the tongue box, galley, environmental control unit (nope, not a commercial unit), keg, etc.
The basic TD is very easy to make and I wanted to get it posted in this thread to encourage others to give a whirl :wink: too!
BoilermakerFan
Postby mikeschn » Mon Oct 11, 2004 7:34 pm
angib wrote:-use an intersection between the body copy and the block copy to make a hatch
Andrew
I just found out IronCAD doesn't have a boolean intersect command, which doesn't make sense, since it's part of the parasolid kernel. :?:
So I ended up taking a copy of the body with the block already subtracted for the hatch, and subtracting that from the copy of the body, to get the hatch. Whew! :? :shock: Make sense?
Images: 471
Postby angib » Tue Oct 12, 2004 7:31 pm
Mike wrote:So I ended up taking a copy of the body with the block already subtracted for the hatch, and subtracting that from the copy of the body, to get the hatch.
Yup, it pays to be able to think a bit laterally when manipulating solids.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby BoilermakerFan » Wed Oct 13, 2004 7:29 am
mikeschn wrote: So I ended up taking a copy of the body with the block already subtracted for the hatch, and subtracting that from the copy of the body, to get the hatch. Whew! :? :shock: Make sense?
No, but I appreciate you sending me the modified file. Haven't had a chance to do anymore CAD work. Hopefully I'll have a chance this weekend.
BoilermakerFan
wherz the pdf
Postby Guy » Mon Jan 30, 2006 4:34 pm
Dear Mike,
Wherz the tutorial pdf?
Regards,
Guy
Guy
Images: 44
Postby mikeschn » Mon Jan 30, 2006 6:31 pm
It's here...
http://www.mikenchell.com/tutorial/Tutorial.pdf
Have fun...
Images: 471
Return to CAD secrets
