Filling in cut areas and more
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby Randy S. Hager » Thu Oct 02, 2008 6:50 am
Hey, I tried using Setchup to draw my design but, could not figure out how to close up the areas that I needed to erase to make the upper and lower rounded shapes. How do I close these areas up? Also, how do I define the drawn areas with the dimension I want for the plan form? I want 6' 6" width 6' 6" height and 12' length. I can't seem to find a place to define these dimension so I can have the floor plan form set before I make it a solid box to start refining the shape.
Thank you
Randy S. Hager
Randy S. Hager
Postby starleen2 » Thu Oct 02, 2008 10:49 am
down in the lower right pane of the window, there is a small box that gives you the dimesions of a retangle when you draw them out - set for whatever unit of measurement you are using.
starleen2
5th Teardrop Club
Images: 200
Return to CAD secrets
