Easy way to modify the Generic Benroy
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby mikeschn » Sat Jan 28, 2006 3:40 pm
I did something totally different today.
I took the generic benroy profile, and constrained it. That means any dimension can be changed, at will, and the drawing updates automatically.
Why would I do that? To make it easy for you guys to do a "what if" scenaro...
Just download the trial copy of Turbocad Professional... (you can play with it for 15 days).
Lets do an example together.
Here is the drawing as it first opens up:
You decide that the 8' length looks too short for that 80" long bed. You could shorten the bed up to 72", or you could lengthen the benroy. Let's see what 10' looks like...
That looks too long to me. How about you? Well we could make it taller? You could try 54" or even 60" tall. But I am just going to shorten it up a little bit... Lets try 9' long...
That's not too bad. I would probably still play with the size and position of the door and wheel...
Let's turn on the dimensions and see how they look...
Do you want to work on that file a bit? How about you Rooster, since you are in the planning stages for a generic benroy.
Here's the file...
http://www.mikenchell.com/generic_benro ... ained2.TCW
The trial of TurboCAD professional is here...
http://imsi.vcrm2.com/broadbaseema/www/ ... urvey1.jsp
Have fun, and let me know if you have any questions... and or if I should add more detail to this file.
P.S. Andrew, are you using Professional?
Images: 471
Re: Easy way to modify the Generic Benroy
Postby angib » Sat Jan 28, 2006 7:19 pm
Sadly, this gets:
"The requested URL /generic_benroy/benroy_constrained2.TCW was not found on this server."
mikeschn wrote:P.S. Andrew, are you using Professional?
Nope. It now costs silly money, mostly for functions I don't need, so I gave up on the Professional version a couple of versions ago.
At one time, the Professional cost less than twice the Standard - now it's five times!
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Sun Jan 29, 2006 1:49 am
angib wrote:Sadly, this gets:
Some days I just can't type. Try this one.
You might have to try the trial, just to play with constraints! :lol:
Images: 471
Postby angib » Sun Jan 29, 2006 7:02 am
mikeschn wrote:You might have to try the trial, just to play with constraints! :lol:
I ain't putting ma hands in anuther man's constraints. Nooo, suh. Ain't that sorta boy.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Sun Jan 29, 2006 7:27 am
:rofl:
Anyways, here's an interesting page with some animations that you might like to see. Shows some pretty nifty benefits of the D-cubed constraint manager.
http://www10.mcadcafe.com/goto.php?http ... ex_all.htm
Images: 471
Return to CAD secrets
