64" teardrop
Important Information and Stickies...
(Threads with essential information about building teardrops)
64" teardrop
Postby c0nn0rsmail » Tue Mar 24, 2015 9:19 pm
So can anyone tell me if I am making a mistake trying to build a 64" wide teardrop. It will have 2" thick walls. So the inside will be 60" wide. Am I opening a can of worms going this wide or is it possible? Any help would be appreciated. Thx.
c0nn0rsmail
Re: 64" teardrop
Postby tony.latham » Tue Mar 24, 2015 9:57 pm
c0nn0rsmail wrote:So can anyone tell me if I am making a mistake trying to build a 64" wide teardrop. It will have 2" thick walls. So the inside will be 60" wide. Am I opening a can of worms going this wide or is it possible? Any help would be appreciated. Thx.
I'll vote yes, on the can-a-worms.
I'm a proponent of sandwiched walls; 3/4" or 1/2" framing/insulation sheethed in 1/4" or 1/8" plywood. Out of curiousity, why 2" walls? If it's insulation, I think it's overkill.
A queen-sized good foam mattress will fit inside a 60" teardrop with those walls.
Re: 64" teardrop
Postby dales133 » Tue Mar 24, 2015 10:12 pm
What's 64 in metric?
dales133
Re: 64" teardrop
Postby Redneck Teepee » Tue Mar 24, 2015 10:21 pm
dales133 wrote:What's 64 in metric?
1625.6 mm
Redneck Teepee
Images: 21
Re: 64" teardrop
Postby dales133 » Tue Mar 24, 2015 10:23 pm
Ahhhh thanks.
Mines 1590...1540 inside
dales133
Re: 64" teardrop
Postby c0nn0rsmail » Wed Mar 25, 2015 7:52 pm
Hey yeah was going to use 1/2 plywood for the inside walls 1" insulation and 1/4" outside wall, i'm thinking its overkill.
c0nn0rsmail
Re: 64" teardrop
Postby tony.latham » Wed Mar 25, 2015 8:07 pm
I like to use 1/4" subflooring in and out. It's built for moist conditions and the stuff my lumber yard gets, I think it's Russian birch, is gorgeous. With either a skeletonized 1/2" or 3/4" interior and foam, it's plenty strong.
T :beer:
Re: 64" teardrop
Postby Esteban » Wed May 13, 2015 4:29 pm
You'll be fine building a 64" wide (outside) teardrop. I, too, question the need for 2" thick walls. It would imply you're building with extra heavy framing and/or extra thick insulation into them. If you want to use a queen sized bed inside it's nice to have a little room on the sides so you can more easily tuck in sheets and blankets between the bed and the walls.
I will build my teardrop 64" wide too. The cabin walls will have 1/4" plywood outside, 1" sandwich framing and insulation, with 1/8" plywood on the inside skin. That totals 1-3/8" for each wall. Another reason I'm building 64" wide is to have space on the roof to mount a Grape Solar 160 watt solar panel to it which is 58" long. Using Instapark glue-on solar panel mounting brackets it fits well across the roof.
Steve - SLO, CA
Esteban
Images: 15
Re: 64" teardrop
Postby desertmoose » Wed May 13, 2015 4:49 pm
Ours is 60" inside, with 1/2 ply outside, 1-1/2 insulation and 1/4 paneling inside, Comes to 64.5 or so outside.
You'll have some drop from running the sheets sideways on the roof, but that's about the extent of it.
Sam
desertmoose
Images: 98
Return to Essential Information about building teardrops
