Solar panels
Important Information and Stickies...
(Threads with essential information about building teardrops)
Re: Solar panels
Postby Esteban » Sun Sep 04, 2016 1:53 pm
solarblvd.com (as of 9/4/2016) has great prices for solar panels that could be mounted on a teardrop trailer:
Solar Cynergy 80 Watt 12 Volt Solar Panel only $59.00
Solar Cynergy 100 Watt 12 Volt Solar Panel only $80.00
Solar Cynergy 120 Watt 12 Volt Solar Panel only $96.00
Solar Cynergy 140 Watt 12 Volt Solar Panel only $112.00
Solar Cynergy 160 Watt 12V Monocrystalline Solar Panel only $115.00
:thumbsup: These prices seem compellingly good.
The 120 watt panel seems like the best buy because it will provide (more than) enough power for most users and fit on the roof of most teardrop trailers. Here are it's specs:
Model Name: PV-SC120J12
Number of Cells: 36 cells in series (4 x 9)
Max Power: 120Wp
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 7.50
Maximum Power Voltage (Vmp): 17.0
Maximum Power Current (Imp): 7.00
Dimensions (inches): 50.98 X 26.22 X 1.38
Weight: 28.66 pounds
Steve - SLO, CA
Esteban
Images: 15
Return to Essential Information about building teardrops
