Help please! Finishing an unfinished interior walls.
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby SheCamps » Fri Jun 09, 2017 6:12 pm
I'm the proud owner of a new mostly finished teardrop. The wood inside is birch plywood. I like the blonde look to the wood so I'm not going to stain it. Are these the steps I need to take... #1 Lightly sand the walls/ceiling with #220 grit sandpaper. #2 Vacuum/wipe down the wood to remove the dust. #3 Apply 2 to 3 coats of polyurethane. Am I missing anything- should I sand after each coat of polyurethane? In my best Elvis voice, thankyouverymuch!
SheCamps
Re: Help please! Finishing an unfinished interior walls.
Postby steinbachbyuma » Sun Jun 11, 2017 4:59 am
1.You can sand between coats, between coats 2 & 3 to me is the important time. Wipe surfaces down between coats to collect dust.
2. I would do the floor last, and have a drop cloth. I would start with the ceiling.
3. Ventilation is important.
4. Try to may yourself comfortable, take your time. Think of it was a weekend project that your going to do other chores between coats.
steinbachbyuma
Postby SheCamps » Tue Jun 13, 2017 6:25 pm
Thank you for the advice- especially about being well-ventilated!
SheCamps
Postby kramergwt » Wed Jul 19, 2017 12:02 am
When you wipe down surfaces after sanding between coats use clean rags slightly dampened with mineral spirits.
Sent from my iPad using Tapatalk Pro
kramergwt
Return to Essential Information about building teardrops
