Oil Based Polyurethane Smell
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby rhkabc » Fri Feb 16, 2018 2:59 pm
Hi All,
I am new to this forum and have definitely benefitted from all the good advice offered here. I recently purchased a 4x8 teardrop that had been sitting outdoors for a number of years. My kids and I are having a great time rebuilding it. My question pertains to my use of oil based polyurethane on the interior walls. I purchased 1/8 inch birch for the new walls, stained them then coated them with oil-based Minwax polyurethane. It has been a few weeks and the polyurethane continues to smell when the doors and hatch are closed. The smell is bad enough so that the trailer is not usable. Anybody have any tips on how to remedy the smell?
Thanks in advance.
Rich
rhkabc
Re: Oil Based Polyurethane Smell
Postby Woodbutcher » Fri Feb 16, 2018 3:32 pm
It will go away. Leave as much ventilation as you can go through the trailer. If you have a garage, leave it in there with the doors open a couple weeks.
Woodbutcher
Postby rhkabc » Sat Feb 17, 2018 1:48 pm
Thanks. I'll keep plugging away.
rhkabc
Postby Nodrog » Wed Feb 21, 2018 8:03 pm
Hi- I will put my .02 in... put a fan in there, air movement will help a lot! Maybe 2 fans! Hopefully it's warm enough where you are to facilitate the evaporation of solvents. Also, what he said, time will get it done....Good luck with the project! Gordon
Nodrog
Images: 36
Postby absolutsnwbrdr » Thu Feb 22, 2018 8:54 am
A little late for this project, but next time try the water-based, oil-modified Polyurethane. Quite a bit more expensive, but no odor, a great finish, and water cleanup.
Zach
absolutsnwbrdr
Images: 410
Postby ae6black » Thu Feb 22, 2018 3:29 pm
I used water based poly on my build. I also had a lot of water blow through my hurricane hinge in a high wind area and it literally washed off the water based poly that I had on my floor. I ended up using the oil based later on top of the water. It only stinks for awhile. A couple of weeks and you won't notice it any more.
Art
ae6black
Images: 19
Postby rhkabc » Thu Feb 22, 2018 3:50 pm
Great pics absolut and I had never heard of Tearjerkers before. Glad I clicked on your link!
Ae6 - interesting. I hope other people respond with their experiences.
Thanks guys.
rhkabc
Return to Essential Information about building teardrops
