Off Road Teardrop for heavy rockcrawling
Moderator: Sonetpro
Re: Off Road Teardrop for heavy rockcrawling
Postby dales133 » Fri Jan 01, 2016 12:08 am
Youll get the tregg style hitch i posted off ebay.
Braked or non brake versions
dales133
Postby Birdman » Tue Jan 05, 2016 7:24 am
Duffdog wrote:About the pintle hitch. You don't find it noisy and clanky? I have one of those on my towable generator and its really kind of annoying. Do you use one of those cone/pintle adapter things?
Nice fullsize wheeler!
Anybody know a US dealer that sells the off road hitches?
I dont find the pintle annoying, but i also put my big cooler on the tong so it keeps alot of the weight on the hitch so it doesn't bang around.
Offroad it makes a bit, but atleast i know its still there LOL.
but i like simple, the pintle is rated for 6.5 ton, so knowing that i dont have to worry about it breaking is something i like to know. it will flop the trailer over before the receiver breaks.
Thanks.
:beer:
Birdman
Postby toygoose » Wed Jan 06, 2016 6:50 pm
You can check out the MaxPouler from AT.
http://store.adventuretrailers.com/prod ... upler.html
toygoose
Postby titanpat57 » Sun Jan 10, 2016 8:13 pm
You have the Lock and Roll https://locknroll.com
and the Max Coupler http://www.kilbystore.com/maxcoupler.html which is what use...both are great products.
titanpat57
Images: 139
Postby Duffdog » Tue Jan 12, 2016 9:41 pm
I worked on the trailer some more, finished the sides roof and started work on the galley.
inside trailer side view
IMG_20151206_194744_536 copy.jpg (133.29 KiB) Viewed 4636 times
galley shelf copy.jpg (171.53 KiB) Viewed 4636 times
door inside skin copy.jpg (193.16 KiB) Viewed 4636 times
Duffdog
Postby Duffdog » Tue Jan 12, 2016 9:44 pm
more pics of the build. In the galley area I'm making an angled shelf for more storage space. the rear of the galley has slides that open to the inside to grab a snack while inside so that you don't have to go outside if its raining or snowing.
side shelf copy.jpg (163.74 KiB) Viewed 4639 times
side shelf frame copy.jpg (171.79 KiB) Viewed 4639 times
roofline rear copy.jpg (210.86 KiB) Viewed 4639 times
Duffdog
Postby FredSB » Wed Aug 17, 2016 12:33 pm
i look forward to seeing the complete build.
Zombie apocalypse, yup, i think you would be ready lol :thumbsup:
FredSB
Postby Duffdog » Wed Nov 16, 2016 2:14 am
more progress. Skinning with 1/8 plywood. note the insulation between the skin and the inner plywood. Just stapled and glued it into place. The windows came from an RV junkyard complete with sliders, screens and inside mount plates. All points were waterproofed with loctite marine sealant. Also notice the hydraulic high lift trailer jacks on the rear for use on very uneven terrain. There will be 4 installed. The front box is a 48" wide truck box from Tractor supply with a locking door. I was surprised at how thick the steel is on those truck boxes. This pic also shows the rear door that I made which extends with gas shocks overhead to act as a shelter when its raining/snowing and you are cooking. The trailer also has a completely new suspension made from Trail gear shackles and some Toyota 4runner rear lift springs I had laying around that I never installed on my ex-gf's truck (bonus!) The axle now has about 12" of upwards articulation.
trailer part siding.jpg (222.31 KiB) Viewed 3954 times
door side with RV window installed and skinned with vent cover for galley fan. The roofing material is bituthene 3000, I thought it would be the best to stop any leaks. Note the aluminum plate on the roof, that is the side of the solar panel array I mounted to the roof which locks into place with detent pins when driving and can be released to angle toward the sun by 20 degrees for winter months and held by a single gas shock in the center
door side skinned window.jpg (455.69 KiB) Viewed 3954 times
driver side of trailer with 2nd window
dr side window skinned.jpg (619.76 KiB) Viewed 3954 times
Duffdog
