Hello from Bay Area, California
Postby sned » Wed Sep 02, 2015 12:33 pm
Wanted to stop by and say hello. I’ve been lurking off and on for couple months and decided to not only join up but to build my own teardrop trailer.
Since I suck at designing I’m looking at going with Vintage Technologies 5x8 plans and templet, but always open to suggestions and will continue to search tnttt and web for more ideas.
Now I need to find a 5x8 trailer to start things off.
Allen
sned
Re: Hello from Bay Area, California
Postby Vedette » Wed Sep 02, 2015 10:27 pm
Depending on your Budget, Your Needs, and Personal Skills? :thinking:
The possibilities are endless........but, do your homework!
There is a ton of information here! ;)
Welcome to the Forum
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby S. Heisley » Thu Sep 03, 2015 11:36 pm
Welcome to the forum!
If you're building with plywood, there's this one, which efficiently uses the most of your plywood and space:
http://www.mikenchell.com/images/GenericBenroyPlans.pdf
Also, there's an entire design library here:
http://www.angib.pwp.blueyonder.co.uk/t ... tear00.htm
If you're building with foam, canvas, and TitebondII, check out the Foamie section. I'd say they are on the "cutting edge" (pun); but, be prepared to do a little reading.
