Fossilized
Fossilized
Postby Fossilized » Thu May 05, 2022 5:34 pm
Hi folks
I've been a happy owner of a 1950s 5 x 12 teardrop for 10 years. Do to health concerns my trailer has deteriorated and I'd like to rebuild. I am wondering if anyone has a material list .ie: plywood sheets
Any help would be appreciated. Gary
Fossilized
Re: Fossilized
Postby Greg M » Sun May 08, 2022 12:47 am
If you send us some pictures we’ll probably be able to help. Do you know the manufacturer or anything else that could help?
Greg M
*Geek Extraordinaire
Images: 85
Re: Fossilized
Postby Ron Dickey » Thu Jun 02, 2022 9:45 pm
Greg welcome your are in the right place.
Teardrops can be addictive.
There are a lot of people here that can help you but you need to look in the areas.
That you feel you need to know about.
also try and donate to the sight if you can afford.
also start a Build Journals others will watch your work, pictures are the best way.
Best of luck on your build.
and look for how make a gallery too.
121377......134179
Ron Dickey
Images: 711
Re: Fossilized
Postby tony.latham » Fri Jun 03, 2022 12:06 pm
Fossilized wrote:Hi folks
The number of sheets depends on how you plan to construct.
I use 11 sheets of 5'x5' 1/8" Baltic, 2 or 3 sheets of 1/2" and 2 sheets of 3/4" for a build. All Baltic.
But I use a fair amount of 3/4" CDX and 1/4" subflooring. And that stuff is easily obtained and there's no reason not to buy it as you need it instead of stockpiling.
:frightened:
