Where did you source the li-ion battery in your trailer?OverTheTopCargoTrailer wrote:Jwh
" I'm trying to keep everything in the trailer, except for vent covers"
I have a 12k btu mini split completely inside my trailer , both units. Has soft stsrt, 200 watts, runs on 100% solar only uses about 250 watts per hour.
Cheers
Overthetopcargotrailer
yycwrangler wrote:lrrowe
do you have any pics regarding mounting the AC in your false wall. I have a ramp which we want to be able to use. I've been considering building a small wall, at the rear door, that would not obstruct us from walking out the back of the trailer and using the ramp as a deck. I would then use heavy curtains to block off the rest of the rear door area to prevent as much heat from getting in. My only concern with this is in the evening we most likely would like to close the ramp door so as nosey bears don't poke their heads in (Rocky Mountains). This would prevent the AC from being able to draw in any air for cooling (hope that makes sense)
thoughts?
Al
