Picking up the 7x18 ct tomorrow morning. Can hardly believe it. We started designing/dreaming in the summer. I've probably sunk 100 hours into research and design so far. And after one failed delivery (the manufacturer put the side door in the wrong spot) and therefore a 3 month delay, I'm finally going to get to start.
So my main question is should I put insulation in first, then wiring, or the other way around, but I also welcome other comments. I have a few days of spring break to make some good initial progress, and here is what I'm thinking.
1. take off wall plywood
2. Briefly pull up flooring and put some paint on the bottom side (put it right back down)
3. Insulate or wire (my reading leans me to insulate first) (oh and cut the holes for the electrical and water and exterior shower hook ups)
4. Wire or insulate
5. Wall plywood back on
6. Ceiling Lauan on
7. Paint walls and floor
8. start constructing interior spaces (beds, storage, dinette, kitchen etc.
9. plumbing and water tanks (this is more a function of the amount of time I have and needing to be able to sleep in it before I need it to have functioning plumbing, plus I'm doing all my lines inside the trailer, so nothing really to stop me from doing it after construction)
I feel pretty comfortable with the latter steps. its the insulation/wire order that i"m thinking mostly about.
