Perseverance Rover - 7x16 Cargo Conversion
Re: Perseverance Rover - 7x16 Cargo Conversion
Postby cwaet » Fri Apr 01, 2022 1:05 pm
I realize this forum is all about the builds, but figured I would share a few pictures as to my motivation for building a trailer in the first place. 168676168675168672168671
7x16 Cargo Trailer Conversion - Build #1 viewtopic.php?f=42&t=73720
Pacific Northwest
cwaet
Images: 48
Postby cwaet » Fri Apr 01, 2022 1:07 pm
Ended up finding a tongue box that will fit the 11 lb propane tank. Had a local shop build a flexible propane line with the right fittings on each end. It only runs to the Truma combi heater/water heater. I'd like to find a way to branch it off to the coleman stove in the back, but haven't figured out how given the different psi needed for each appliance. 168673168670
Pacific Northwest
cwaet
Images: 48
Postby foxontherun » Fri Apr 01, 2022 3:38 pm
cwaet wrote:164932
Good looking build. :thumbsup: What kind of awning cover do you have over the rear of your trailer in this picture? I am looking for a cover to use for my trailer but haven't found one yet that will hang over my roof a little like your picture looks like.
Thanks!
Harry :)
foxontherun
Images: 71
Postby cwaet » Fri Apr 01, 2022 3:55 pm
foxontherun wrote:
cwaet wrote:164932
Thanks!
Harry :)
In that picture I actually had a standard 10x10 4 post awning propped up on the back of the trailer so I could work in the rain. For a permanent awning I installed the OVS 270 deg awning, which works pretty well. Next time I take the trailer out I'll try to snag a few more pictures of it deployed.
Pacific Northwest
cwaet
Images: 48
Postby cwaet » Sun May 01, 2022 10:05 pm
The original design was going to be a fixed wall between the sleeping area and the galley in the rear. I've put off building it since we are still having to take the mattress out to tinker with different things and ultimately we ended up really enjoying the open air. Built a frame and my MIL helped out sewing a screen with zippers, velcro on the edges. Turned out pretty well and now we can keep the back doors open the whole day.
169028
169026
Speaking of back cargo doors, I replaced the OSB with some plastic shower wall. It ended up being way to flimsy and seems to bow in the sun. Any ideas on a better product to use? To see the edges I used some white gorilla tape that isnt sticking as well as I'd hoped so I'm open to suggestions, just needs to be waterproof and hopefully light. Here is a picture of one door, although none of the issues show up in the picture:
169027
Pacific Northwest
cwaet
Images: 48
