Only 1 charge controller is needed
actually if you go to 24 volts - you can double the panels
The rule pretty much is if the panel amps
or volts
are within 10% then you can slap the stuff together....what happens is that you then go to the lowest amps or to the lowest volts,
in my case I would drop from 30 volts to 27.6 for all 8 panels
Of course its overkill ....the whole project is overkill
The project does have SMALL
cost over runs ...like any home remodel....or NASA project going to Marsat least its one of a kind & I could always use the stuff on a small house or remove and install on larger trailer...??
I got a friend who's crazy wife is dropping $100k on a average kitchen remodel, believe the old kitchen was great.
Mostly its a fun project breaking my NUT on how to install all that crap....into a cargo trailer vs. a house
There are those people who buy those tiny houses on 6 x 12 trailers for $50k.....
Those guys are much, much, much, much more Fruit Loops then I am
Besides when it comes to ac - its only getting hotter out there
hopefully somebody learns something from all my screw ups - that they can
use on their house or CT project ?
The old water heater had 1/2" - this has the standard 3/4" MPT
Not much you can do about the imported dog breath.
