6x12 BUG-OUT BOX BUiLD
Re: 6x12 BUG-OUT BOX BUiLD
Postby BigDave_185 » Fri Apr 03, 2020 11:56 pm
You pulled 5/8th floor for 1/2 to save weight correct?
BigDave_185
Postby onehoser » Sat Apr 04, 2020 4:21 am
BigDave_185 wrote:You pulled 5/8th floor for 1/2 to save weight correct?
i removed 3/4" osb which weighs 80lbs per sheet to be replaced by 1/2" plywood which weighs 40lbs per sheet. yes, to save weight. the combined weight of the osb floors and walls is 500lbs, half of the weight of the entire trailer (980lbs) when done i will have shaved off 250lbs.
i'm towing with a jeep wrangler which has a tow capacity of 2,000lbs and 200lb tongue weight so every pound i save is a bonus
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby BigDave_185 » Sat Apr 04, 2020 8:58 am
Copy that
BigDave_185
Postby onehoser » Sun Apr 05, 2020 9:37 am
new floor cut, fitted and the bottom side painted, should be dry enough to handle for installation this afternoon
onehoser
Postby flboy » Sun Apr 05, 2020 2:18 pm
Great idea to get that all sealed up and painted before you put it back down. :thumbsup: :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby onehoser » Wed Apr 08, 2020 7:37 am
floor installed and top side painted. next job is to decide the locations of the 2 new windows
onehoser
Postby onehoser » Wed Apr 08, 2020 7:43 am
onehoser
Postby Modstock » Wed Apr 08, 2020 9:44 pm
Looking good.
Sent from my H1611 using Tapatalk
Modstock
Postby NevadaBlue » Thu Apr 23, 2020 9:49 pm
Nice work. Watching, this will be fun. :)
Ken
NevadaBlue
Postby onehoser » Fri Apr 24, 2020 5:13 am
next step is to cut out the windows, i've decided the locations, made up the cut-out template, and now i'm waiting for a break in the weather, we've been getting a mixture of rain, snow and winds so hopefully that will ease up soon
onehoser
Postby Pursuitofsolitude » Fri Apr 24, 2020 7:44 am
Looks like a nice build; good luck!
Pursuitofsolitude
Postby onehoser » Sat Apr 25, 2020 12:01 pm
windows are inImage
onehoser
Postby onehoser » Sat Apr 25, 2020 12:02 pm
onehoser
Postby flboy » Sat Apr 25, 2020 12:14 pm
Nice work! they look great. Make sure to give them the old garden hose test before you button up the walls. Just a good test and easy fix now if any leak issues.
Don (Flboy)
flboy
Images: 378
Postby McDave » Sun Apr 26, 2020 12:36 am
Nice job, Hoser!
McDave
McDave
Images: 412
