Karebru wrote:Just some progress pictures...
One of the less enjoyable parts of the process...
Gluing the aluminum skin to the new steel and keeping it flat.
[/size]Karebru wrote:They're never really finished, are they.![]()
After our fourth long weekend trip in our camper, we decided we're very happy with it, except for the sleeping arrangements.
After 41 years of sleeping side by side in the same bed, the sentiment is still there, but the old bodies need to be able to make bathroom visits in the middle of the night without having to climb over the top of each other.
Through the building processes, I bounced around several ideas for bunk arrangements. What I ended up with worked well for what it was, but we both agree that we need to be able to just sit up, put our feet on the floor, and stand up.
So... It's back to the original plan of split fold-up bunks with an aisle down the middle.
On the road, our mattresses ride on edge, between the cabinets up front. So I didn't need to allow for their thickness when hinging the bed platforms. This really opened up the cargo area, compared to the old set up.
(I need to make a cover for the water tank surround.)
Staryder61 wrote:My better half and I have just sat here and went through your complete 7' X16' build log:
Really liked the way you reconfigured the bed set up..
Your build gave us a lot of information and designing ideas for ours.
Grummy wrote:
I have to find a "friend" that will let me build out their trailer ! I sure want to do another, but have you seen those trailer PRICES !
Staryder61 wrote:Karebru, what have you used to cut the holes through the sides? Maybe I've missed it if you've said.
I've read different ones use jig saws, some body grinder cut off tools with thin discs.
Karebru wrote:Staryder61 wrote:Karebru, what have you used to cut the holes through the sides? Maybe I've missed it if you've said.
To me, a jigsaw with a blade for thin metal is the easiest to control, and it cuts like butter. Drill a starter hole. Set the blade oscillation on zero (If the saw has it.) for the cleanest cut.
And again, make sure everything is covered with masking tape to protect it from scratching.
Staryder61 wrote:Karebru, just popping in to see if you have updated here yet?
Enjoy the weekend..
Karebru wrote:Staryder61 wrote:Karebru, just popping in to see if you have updated here yet?
Enjoy the weekend..
LOL! Funny you should ask.
The finisher has been draggin' his a$$ about getting all the trim and stuff done and back to me. And since it's his trailer, I put the project on the back burner.
He showed up today, out of the blue, and dropped off a bunch of stuff. So I guess I'd better get back on it.
First thing to be done at this point, is cut the flooring to fit and glue it down. That is, after Bondo-ing plywood joints and screw holes.![]()
Hopefully this week.
