I finally connected and leak tested the propane system. That is a high pressure outlet for camp stove use outside.
The Truckfridge with its extra 2" wrap of polyiso insulation. The extra 2" for the bottom is not attached to the fridge but is under the plywood covered base just visible at lower right.
Truckfridge inserted into its place. The bed platform is painted. Still have to make doors for the underneath storage area; water tank, pump etc visible. Some of my parts mess visible too. The A/C with remote control temporarily installed in the door cut out
The view from outside the door. Shower pan and walls in place. Fridge in place. The sink in a mockup installation with faucet.
Closer and different angle view of the shower.
View from the rear. Walls for the shower, pipes visible are hot & cold supply to shower and the waste water tank vent pipe. Vent is still to be hooked up through the roof. Plywood walls finished in Minwax Polycrylic Clear Satin. (water based... love it as there is almost no odor at all. Lasts well too as I have used it on other projects for something like 10 years or more.
Interior nose view. Shelves to be added under counter. Our plan is to use storage boxes under there to hold "stuff".
Outside view of the A/C. I'll explain more later as I finish the mounting, but in brief the two vertical things are steel reinforcements to help spread the weight of the A/C. They are spaced wide enough to permit a platform at the bottom for the Honda EU2000i to be added.
