jr9744 wrote:I love the way you did your walls. It all looks great!
Thanks, I am enjoying your build as well.
Started fabbing my overhead luggage/storage rack.
Cut and pre drilled a piece of 1/2" baltic birch for the bottom.
After determining where the rack goes, I cut the molding and did a little wildcat drilling to find the roof bows.
I got spooked that just one #10 metal screw into each of 3 roof bows was maybe a little shy.
So I built these pieces to get 2 more screws in each tube. Notice the slight angle cut, this will match the roof slope.
Welded the screw tabs on. 9 screws ought to do the trick.
In the process of lacquering the board. "Why am I floating and everything is spinning"
There she is all mounted. The wall studs were much easier to find since one was exposed from the window cut out.
And YES I plan on getting a more manly sheet for the mattress.
Hopefully finish up the rack Mon or Tue. Stay tuned!
