6x10 Cargo Mate Challenger
Re: 6x10 Cargo Mate Challenger
Postby dirtsailor2003 » Sat Apr 10, 2021 6:43 pm
dirtsailor2003
Postby BigDave_185 » Sat Apr 10, 2021 8:15 pm
Where did you source your fuel cell? Good looking set up and I plan o doing the exact same cheapo from Amazon/eBay and mounding under a cabinet in the front of the trailer
BigDave_185
Postby featherliteCT1 » Sun Apr 11, 2021 2:41 pm
I really like my diesel heater and hope you will enjoy yours as much as I enjoy mine. Just a couple of observations:
1. My understanding from reading the Chinese diesel heater forums is that, if intake combustion air is sucked from inside the trailer, rather than from the outside, a vacuum of negative pressure can be created inside the trailer. Then, if the heater ever malfunctions, exhaust gases can leak into the trailer. I think John McK also talks about this issue and explains the different ways the unit can malfunction. If you are not already familiar with John McK, below is the link to his multi part series. I highly recommend this series.
Some people place a removeable cover over the inlet pipe to keep out bugs and debris. Same with the exhaust.
https://www.youtube.com/user/johnmck1147/videos
2. Also, it is recommended that the fuel tank be mounted below the fuel pump. If the fuel pump malfunctions, fuel can then pour through the pump and flood the inside of the heater. Perhaps that issue could easily be solved by putting a shut off valve upstream, between the pump and the fuel tank.
featherliteCT1
Postby dirtsailor2003 » Sun Apr 11, 2021 6:53 pm
BigDave_185 wrote:Where did you source your fuel cell? Good looking set up and I plan o doing the exact same cheapo from Amazon/eBay and mounding under a cabinet in the front of the trailer
Amazon.
dirtsailor2003
Amazon.
https://www.amazon.com/dp/B07R652M8B/re ... UTF8&psc=1
Last edited by dirtsailor2003 on Sun Apr 11, 2021 8:07 pm, edited 1 time in total.
dirtsailor2003
Postby dirtsailor2003 » Sun Apr 11, 2021 6:58 pm
featherliteCT1 wrote:I really like my diesel heater and hope you will enjoy yours as much as I enjoy mine. Just a couple of observations:
I’m not worried about a negative vacuum. I always have a window open even in winter so the air supply won’t be depleted.
The fuel tank will be below the pump. It’s going on the floor. The draw will be from one of the lower ports.
dirtsailor2003
Postby featherliteCT1 » Sun Apr 11, 2021 7:04 pm
:thumbsup: :applause:
featherliteCT1
Postby dirtsailor2003 » Tue Apr 13, 2021 3:50 pm
Changed out the fill lid today and rigged up the supply line.
I’m plumbing the fill through the wall so I had to remove the lid and put a nipple on. I thought the screws would have been tapped into the top but they weren’t. There is a ring inside that the screws go into. Thankfully I have small hands. I was able to hold the ring and get one screw started. Then I used a pick through the screw holes to pull the ring up and attach another screw opposite. Did they same on the other side. There’s also a gasket that I had to keep in line. Worked out and got everything in place.
The tank has AN 10 fittings. Overkill for this but seems to be working out good. The vent I bought to put through the wall will work out good size wise. The nipple that came with the heater for the provided tank actually fits perfectly in the hose I bought for the vent.I used a small chunk to connect it to the AN nipple. Yes it’s fuel rated hose.
I’m waiting on my fuel hose for the fill to show up and the vent. Once I get all of that I will be able to put it all together and fire things up.
dirtsailor2003
Postby BigDave_185 » Tue Apr 13, 2021 6:23 pm
Will you keep track of costs. I’m looking at the exact or trying to mount fuel external
BigDave_185
Postby dirtsailor2003 » Wed Apr 14, 2021 12:06 pm
BigDave_185 wrote:Will you keep track of costs. I’m looking at the exact or trying to mount fuel external
Are you sure you want to know?
Prices not including the $150.00 heater.
dirtsailor2003
Postby BigDave_185 » Wed Apr 14, 2021 3:48 pm
100% want to know. So far nothing on the trailer conversion has been cheap lol why stop now
I love the tank and the fill From outside. Mount it on my driver side so I can catch it after I fill my truck, perfect !
BigDave_185
Postby dirtsailor2003 » Wed Apr 21, 2021 8:53 am
Still haven't wrapped up my tank install. But I am close. The vent I ordered traveled from Florida to Portland Oregon, then it went to Washington, California, back to Washington. Supposedly it made it back to Portland, and is now out for delivery. So much for Prime shipping...
As soon as I have that I can finish everything up and run the heater. Would've been nice on last weekends camp trip. Couple nights the temps got down to the 20's. Brrrrrrrr!
Good news is I got the heater wired up and no error codes!!!
dirtsailor2003
Postby dirtsailor2003 » Wed Apr 21, 2021 11:21 pm
Vent showed up today after it’s across country west coast trip.
Installed. Next trip is to the gas station to get some diesel! Then fire it up.
Checked all my installed fittings after last weekends 150+ mile washboard trip and they are all in place and still tight. Shouldn’t be any leaks.
dirtsailor2003
Postby dirtsailor2003 » Fri Apr 23, 2021 10:40 pm
Fired up the heater today.
No issues runs great!
Gave off some nasty exhaust at first. Not sure what they put in that engine but it was bad. Once it burnt off no visible exhaust at all. Running standard diesel.
Definitely going to heat up the 6x10 when it’s cold.
dirtsailor2003
Postby hankaye » Sat Apr 24, 2021 7:52 am
dusty-swab, Howdy;
:applause: :thumbsup: :thumbsup: :applause:
hank
hankaye
