Friday Update:
I've got this thing about as taken apart as I'm gonna go with it...
The only other things are the ramp and side door to insulate them.
Anybody know off the top of your head, what size Torx bit fits the hinge bolts? Looks like a 50 or 60.
Speaking of Torx... I've had to remove several screws that are somewhere in between a 15 and a 20. What the heck?
I ended up cutting slot in them with a die grinder and using a flat screw driver. The reassembly will be done with phillips or square drives.
All my electric is exposed now, and it ain't all pretty.
Here's the rat's nest in the box under the lock-out battery.
I think I'll install an access hatch in the floor over it for easy trouble shooting and maintenance. It will be out of the way in my little toilet room.
Here's the main bundle for the running lights, on it's way up to the roof. I don't know who came up with this design.
A length of plastic tubing over the wires as it goes through here will give them some protection.
I'm going to coat the underside of my floor panels with polyurethane as soon as we get some dry weather. Then screw them back down with construction adhesive so the don't creak.
I'm getting really close to changing directions on this project... Building instead of disassembling.
The refrigerator I ordered came... I really like it!
I've been following it's return trip to Kentucky on UPS tracking. It arrived there today.
Please, PLEASE! just send me a replacement without any hassles.
I'm not going outside until the temperature is above my age.
