I ordered windows for my ct, and have a few questions about windows and the installation. The windows arrived and I'm waiting on the trim rings to arrive, special order due wall thickness.
How does the trim ring attach to the window?
Does it attach with screws or clips?
If it attaches with screws, when you tighten the screws, does it make a tighter fit on the outside ring to the trailer? I hope it does, cause the outside ring is metal and I think I have to put some kind of caulk under ring to get it to seal better.
I've looked at other threads on windows and none of them mentioned this. They were mostly about cutting the hole out for the windows. Some great advice as usual
