Sealing Windows
Sealing Windows
Postby milkbone » Sun Dec 26, 2010 12:25 pm
When installing a window on CT people say use (I think) butyl tape to seal the window. I was wondering if it would be alright to use plumbers putty instead. Hell you use it sealing your tub and sinks. Just wondering pros and cons or if its advisable?
milkbone
Images: 6
Postby madjack » Sun Dec 26, 2010 9:10 pm
...use the tape...plumbers putty will dry up and crack...the tape won't and is more "sticky" as well......................
Postby pete42 » Mon Dec 27, 2010 8:48 am
I have only replaced 2 windows and I used butyl tape when installing them.
I don't really know about plummers putty
but the butyl tape is easy to work with and comes in different widths
so I say go with the butyl tape
pete42
Postby Prem » Mon Dec 27, 2010 11:08 am
:thumbsup: What Madjack and Pete said! :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Windows
Postby drcurran » Mon Dec 27, 2010 4:13 pm
Have to agree with madjack. My guess is that while plumbers putty seems very similar it is used indoors and would not handle the temp changes very well. OK just my .02
Dan
"I'm not as good as I once was, but I'm as good once as I ever was."
TK
drcurran
Images: 20
Postby SmilinJack » Mon Dec 27, 2010 5:44 pm
We know butyl tape works, and it isn't very expensive. Why take the chance?
Jack
SmilinJack
Images: 32
Postby milkbone » Tue Dec 28, 2010 11:56 am
Thanks everyone for the input. Looks like butyl tape it is, better safe than redoing it later on.
milkbone
Images: 6
Postby MikeW » Tue Dec 28, 2010 1:03 pm
When working for an RV dealership, we used butyl tape and then added a thin silicone bead around the top and down the sides of the window frame.
MikeW
Postby pete42 » Tue Dec 28, 2010 4:49 pm
MikeW wrote:When working for an RV dealership, we used butyl tape and then added a thin silicone bead around the top and down the sides of the window frame.
I never use silicone just the butyl tape.
The reason I never used silicone was the mess it left.
if you do use silicone be sure not to cover the "weep" holes along the bottom of the window.
pete42
Postby MikeW » Tue Dec 28, 2010 10:14 pm
Definitely want to leave the weep holes clear. If applied correctly silicone can leave a nice neat bead. One thing to remember is don't lay it on too thick. If you have trouble keeping a nice bead a trick is to lay a strip of masking tape where you want the edge of your bead. Once you lay the bead you can smooth it out with the dampened tip of your finger. I have put in dozens of windows this way and I don't think I ever had one come back.
MikeW
Postby MikeW » Tue Dec 28, 2010 10:16 pm
Also might add that we were working flat rate so if the job came back we didn't get paid to fix our shoddy work :o Good way to insure you did it right the first time :thumbsup:
MikeW
Postby Prem » Wed Dec 29, 2010 6:40 pm
My buddy who works as an RV tech at a dealership and does windows all the time never uses silicone. To keep jobs from coming back, he uses double butyl tape.
I tried it. I like single because the window goes farther into the slot for a tight fit. I have NEVER had one leak on me, even years, and 50,000 miles later. Double tape MIGHT be called for IF one were pressing the window into the slot OVER wavy/ribbed aluminum siding.
If you use double tape, expect it to ooze out in the hot weather as the pressure of the clamp squeezes the softer, hotter butyl. Every few days you run a knife around the window to remove excess, sticky butyl. Eventually, you've removed so much excess that it adds up to the entire second layer of butyl tape you put on...and paid for.
:thumbs down:
My goal...
Prem
Images: 144
