pete42 wrote:The only windows I have installed were in a truck van.
I have taken trailer windows out and reseald with butyle tape.
I know you said you didn't want to remove the inside wooden panels
but it seems to me you should so you don't cut any supports if you want the windows installed between the support ribs.
Or if you are thinking of installing longer windows then a framwork needs to be built to replace the support ribs that will need to be removed.
so I would remove the wood.
good luck keep us informed.
Prem wrote:harley-jones,
See:
http://www.mikenchell.com/forums/viewtopic.php?p=735157#735157
and
http://www.mikenchell.com/forums/viewtopic.php?p=735535#735535
