2006 United Cargo slide out build (more new pics)
Postby michiganflipper » Sat Feb 05, 2011 10:34 pm
Last edited by michiganflipper on Sun Feb 20, 2011 7:02 pm, edited 2 times in total.
michiganflipper
Postby droid_ca » Sat Feb 05, 2011 10:54 pm
looking good what are you going to use for the slide mechanism ?? :applause: :applause: :applause:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby michiganflipper » Sat Feb 05, 2011 10:58 pm
they have 100# draw glides at Home depot that I have been looking at
michiganflipper
Postby droid_ca » Sat Feb 05, 2011 11:16 pm
so what are you going to use the space for?
“Fide Canem”
droid_ca
Images: 176
Postby michiganflipper » Sun Feb 06, 2011 8:12 am
with the trailer anly being 6'wide it ias a little cramped when you have the bed sideways like we do so im adding the slide out to give us room for our feet so they are not tight against the wall
michiganflipper
Postby pete42 » Sun Feb 06, 2011 9:38 am
Very good idea and I will be watching to see your process.
pete42
Postby michiganflipper » Sun Feb 06, 2011 1:27 pm
I should have the outside skin off today
michiganflipper
Postby droid_ca » Sun Feb 06, 2011 2:00 pm
sounds good as long as its for a bed or cupboard space I cant see using drawer slides being a problem
“Fide Canem”
droid_ca
Images: 176
Postby michiganflipper » Sun Feb 06, 2011 5:54 pm
here is where i took the skin off to get to the studs
removed the insolation and cut the studs to rough opaening
michiganflipper
Postby michiganflipper » Sun Feb 20, 2011 11:43 am
the plywood for the slideout
side all cut out
Putting the side together I glued and screwed them
test fitting
test fit 2
laying out for the window
cutting out the window
installed with window
looking from the inside
michiganflipper
Postby droid_ca » Sun Feb 20, 2011 12:39 pm
looking really good keep up the good work thanks for sharing :applause: :thumbsup: :applause: :thumbsup:
“Fide Canem”
droid_ca
Images: 176
Postby michiganflipper » Sun Feb 20, 2011 7:01 pm
Starting to skin the slide out
starting to cut out the window
instaled in the trailer
side veiw
front veiw
michiganflipper
Postby Nitroxjunkie71 » Mon Feb 21, 2011 5:35 pm
VERY NICE! :applause:
I can't wait to see it in May! :thumbsup:
Jeff
Image Image Image
Nitroxjunkie71
cargotrlrman
Images: 232
Postby droid_ca » Tue Feb 22, 2011 11:18 am
this is an excellent step by step walk through on how to do this you made it look nice and easy Thank you :applause: :applause: :applause: :applause:
“Fide Canem”
droid_ca
Images: 176
Postby vtx1029 » Tue Feb 22, 2011 11:58 pm
Awesome :thumbsup:
vtx1029
Images: 70
