I started mine I have ? on breaker ground
Postby aqclean » Sat Feb 19, 2011 9:48 pm
Hi All:
I picked up my 6x12vnose haulmark transport two Frdays ago.(interior 5.5 x 13) wish had my camera but my wife took it with her to see our 1st grandson.(2months old).I started today pulling the walls down ...I'm glad I did, The wiring coming in from lights some had nice rubber groomets to protect the wiring comming thru the hole some did not.,Glad I caught that.
I am going to put in the insulation,and start to run the wiring, If I mount the box to a wall stud (metal frame} will this ground it out? (I do have a ground bar in the box also)I am going to ground all the GFIC also. Will this work.I will have no battery power : I read a whole bunch of topics on it',and it seems as long as you test what your plugging into at the campground you should be good to go.
Thank you
Dave in RI
aqclean
Postby michiganflipper » Sat Feb 19, 2011 10:30 pm
yes you will still need to use the ground bar in your panel box. please send lots of pics
michiganflipper
Postby aqclean » Sun Feb 20, 2011 6:16 am
Yes
I will use the bar. I think I read to many post about grounding to the frame and they start to confuse you.
thank you .
Dave in RI
aqclean
