pmowers wrote:Verna- I normally use a drywall square for up to 4 ft, and in combination with an aluminum straight edge for longer work. I was just hoping that the Kreg setup would work for quick cuts, not requiring me to clamp the straight edge to the board.
Michael- I would have to say, I like your style, but the spousal unit has already been asking if I am going to live in this thing. In women-speak, I think that this is getting close to, "It better be good enough to live in, because you will be"
pmowers wrote:Got home from work last night and started finishing up connecting the power converter and wiring. I had thought that I was going to use a 20A GCFI breaker as the main breaker for the trailer and have everything protected. Well, wired the breaker in, plugged the extension cord into the shore power inlet- so far, so good. I was using a standard sized (1 inch) main and the rest of the breakers are 15A tandem- makes for a real tight working environment with 14/2 romex.
Clicked the main breaker on, no bright flashes, no electroshock therapy treatments, no unexpected noises or smells, so I think to my self, now we're cooking, that was sort of a prophetic thought there.
My next step is to test the GCFI breaker by pushing that little yellow button-bad idea. As soon as I press the button, a loud buzzing starts from the breaker, and the magic smoke starts to escape. I stare at it for a second in disbelief, then snap the breaker to the off position, go out and pull the cord out of the shore power inlet. Where the heck did I put the fire extinguisher?
Pull out the GFCI breaker and return it to the store and pick up a plain-jane 20A breaker. Installed it this morning. Connected the rest of the AC lines and breakers. I tied the negative DC lines to a grounding bar and then to the frame. Crimped the ends of the positive DC lines and plugged them into the 12V side of the system. Because I tend to overbuild, I used 12 ga. stranded for the DC, although I am fusing all of the connections at 10A. This meant bigger female spade connectors to handle the wire. How much bigger, I had not realized. When I went to put the front panel back on, the connectors are too tall to allow the panel back on. So I had to replace all of the connectors with slightly shorter ones and give them a slight bend to fit.
Note to self- get ahold of some side-crimp female spade connectors to make things much easier in the future.
Hooked up the shore power, and turned the new main breaker on, then stepped through the rest of the breakers, using the little circuit tester-all good. Converter fan starts, then goes off, all the 12V outlets come live, the microwave wakes up and asks, "What time is it?", and the refrigerator kicks on when I set the thermostat. Hooray! And I didn't even need the fire extinguisher or to call 911.
The outlet count so far is:
120 VAC, 15A (still have room for 3 more breakers)
2 outside near the shore power inlet
3 near countertop
2 in top center cabinet (microwave using 1)
2 in right cabinet (refrigerator using 1)
I plan on running several additional outlets toward the rear of the trailer.
12 VDC 10A (although they can be fused for up to 20A per circuit (45A overall)
2 external near the shore power inlet- these outlets use a 1/4" phone plug/jack set to provide power- I am making 2 adaptors out of a 12V splitter. I will post pictures when I get them done.
1 ceiling and porch lights
1 cigarette type outlet over counter
I also plan on adding several additional 12V outlets around the trailer in the next phase of building.
Additionally I have 2 USB outlets near the countertop on the side of the cabinet.
