Hello, hope someone can help me with this
I am converting a 6x12 cargo trailer and have planned for having both 12v and 120v connections.
I have the 12v connection covered. I bought a 12v fuse block from amazon - https://www.amazon.com/gp/product/B001P6FTHC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1. The wires to all the lights, vent fan and water pump will be going through the fuse block
Below are the questions I have:
1. I already bought a separate inverter and charge converter. What kind of circuit breaker should i get for 120v (30 amp input)? Should it be something like this -
https://www.amazon.com/Square-Schneider-Electric-HOM816M100PC-16-Circuit/dp/B00NO9FJNW/ref=sr_1_2?s=lamps-light&ie=UTF8&qid=1495475704&sr=1-2&keywords=main+Breaker+Load+Center
2. I would be connecting the wires to 2 separate receptacles - which will be used for instant pot, toaster, microwave etc. So, I think I should have a 30 amp fuse on the circuit breaker for the wire coming from the shore connection. And 2 15 amp fuses connecting to the 2 wires going to the receptacle.
Thanks in advance!
