Intro and title, “motobox that my wife would camp in”
Re: Intro and title, “motobox that my wife would camp in”
Postby BigDave_185 » Fri Feb 14, 2020 1:29 am
Sanded the whole floor for epoxy tomorrow, removed all of the un needed strap down points up front, filling those in with bondo and epoxy over.
BigDave_185
Postby BigDave_185 » Sat Feb 15, 2020 12:30 am
Poured down about three gallons of epoxy,
Looks amazing. Second coat tomorrow
BigDave_185
Postby McDave » Sat Feb 15, 2020 12:23 pm
Man, that does look great and it should be bulletproof. Are you gonna use some grit on the ramp? They can be slickery when wet.
I like it. Nice job.
McDave
McDave
Images: 411
Postby BigDave_185 » Sat Feb 15, 2020 1:23 pm
MCDave I am unsure of the finish in the ramp. I will put some of this mixed in with the second coat tonight
https://www.hcconcrete.com/product/sharkgrip/
I have thought about putting down a grip type material on the ramp. I only plan on hauling dirtbikes. Maybe a rzr one day but.... what do you have in mind?
I am completely against sand or course grip in epoxy. It’s hard to clean, hard wear surface on bare feet also.
BigDave_185
Postby BigDave_185 » Sun Feb 16, 2020 6:36 pm
I will just leave this here. Been busy this weekend
BigDave_185
Postby Modstock » Sun Feb 16, 2020 7:09 pm
That pic in the thumbnail looking out the backside I thought, oh no he has a leak.
Looks great.
Sent from my H1611 using Tapatalk
Modstock
Postby BigDave_185 » Sun Feb 16, 2020 10:57 pm
Modstock wrote:That pic in the thumbnail looking out the backside I thought, oh no he has a leak.
Looks great.
Oddly enough there was enough holes in the floor from screws that I have puddles of epoxy under on my new garage floor
BigDave_185
Postby Modstock » Sun Feb 16, 2020 11:03 pm
After switching to the metal roof vent lid, I closed it and the doors. It was super darkness inside , found a hole in the floor where they missed a beam and went straight through.
Siliconed it immediately.
Modstock
Postby BigDave_185 » Sun Feb 16, 2020 11:51 pm
We had some protective plastic down for snowmobiles screwed to the floor in various spots. Those holes were hard to find.
After I figure out plumbing and the grey and fresh water tanks I’ll have the bottom spray foamed in and it won’t matter much.
Need to figure out shower pan to grey water tank attachment, need to plumb the sink pump and shower head pump after a tankless water heater.
Does anyone know if the tankless heaters can be purchased with a pump built in or as a combo ?
BigDave_185
Postby McDave » Wed Feb 19, 2020 10:12 pm
My fresh tank came with pump as combo, tankless heater just came alone, but I love it. It works well with the pump, only heats when water flowing. I used a Hepvo trap and went into the side of the tank. Used a grommet to seal. Also put a by-pass valve on shower drain to drain to ground when acceptable. I only have one tank, black/grey same tank so if I can drain shower to ground saves tank space.
https://hepvo.com/
McDave
McDave
Images: 411
Postby BigDave_185 » Thu Feb 20, 2020 5:38 pm
I know some of you all have fancy drawings and 3D computer images. I don’t have time for that and my free solid works program from school has long since been locked up.
I did draw a kinda scale picture today as I need to figure out my plumbing.
Sink: need hot n cold water and a drain to grey tank
Shower: needs hot n cold and plumbing to grey tank
Toilet: Compost/bag toilet or black water tank I am not sure. I would like to place toilet and tube directly over the two tanks they need. What plumbing fittings to connect them?
I have propane gas line I can run easy enough
I can weld the bed frames up easy enough
I can build cabinets ( it’s what I do for a living) easy enough
Electrical:
What does a guy need to purchase to power two batteries of the 6v origins?
Where can I purchase prefab fresh, grey, black water tanks?
Lots of the links in other threads are dead or no longer functioning
BigDave_185
Postby BigDave_185 » Thu Feb 20, 2020 6:44 pm
Well here is the roof panel color,
BigDave_185
Postby Rainier70 » Sun Feb 23, 2020 10:08 am
Another option that is kind of midway between a black tank toilet and a portable, is a cassette toilet. It is a permanent toilet install that has its black tank above the floor but accessible through an outside hatch. The black tank is on wheels and you dump it manually, but I have seen one that someone had modified to dump with a valve and hose. Just another possibility for those still deciding on their bathroom options.
Here are some examples: https://www.thetford.com/products/toile ... e-toilets/
Rainier70
Images: 244
Postby McDave » Sun Feb 23, 2020 9:13 pm
RV tanks = http://www.ameri-kart.com/Home.aspx
I believe you can just wire the 6v batteries in series and run as a 12v system. Parallel would give you 6v @ 2x Ah. Series would be 2x6v(12v) @ 1xAh.161215
Not great illustration, but I think you can get it.
McDave
Edit: Check these guys for holding tanks and fresh tanks (in plumbing or sanitation)
https://www.rvpartscountry.com/RV-Holdi ... allon.html
McDave
Images: 411
Postby BigDave_185 » Thu Feb 27, 2020 7:01 pm
Found time to spray the last six panels for the roof, I have two extra to use around the bathroom walls after framed
Soon
BigDave_185
