NotJammer wrote:I agree I may home run all CTC wiring including all grounds.
What gauge positive wire from TV engine compartment 12 vc isolator to run to a QR at the rear of my TV? 25 ft run.
I will use the 2017 F150 steel frame as a ground for that circuit. The wiring on F150 was downsized to just enough...
On long driving days, my TV alternator should contribute.
Are you a Ham? I'm a non-operating one. I just listen on my cheapo HT.
onlyridepark wrote:Thanks for all the replies. If I am hearing this right, it is normal and acceptable for all grounds to run back to the battery negative without a chassis ground on the DC circuit. My plan will be for all loads to come back to a common bus bar, then through the shunt and to the Battery negative. It just seemed weird not grounding the battery to chassis. I assume since all loads will come back to battery negative this is why it isn't necessary.
Or did I completely misunderstand everything you guys just said?
flboy wrote:You understood it well and have the right idea. The home run of each negative to a bus bar, then through a shunt to the negative terminal of the battery completes the circuit. On a chassis ground system... put simply, the chassis is just the bus bar.... a very large bus bar where you connect wires closest to the point of use. It just saves a lot of wire. I have a steel frame so not the issues with aluminum and galvanic corrosion.
onlyridepark wrote:it is normal and acceptable for all grounds to run back to the battery negative without a chassis ground on the DC circuit. My plan will be for all loads to come back to a common bus bar, then through the shunt and to the Battery negative.
