Sway Control - Will this help?
Postby CoventryKid » Sun May 06, 2018 10:12 pm
I don't have a problem with my trailer swaying, as in being improperly balanced, etc. It tracks nicely behind our van at all speeds.
But when a truck, or even a car, passes us on a 4-lane hwy, the van gets "pushed aside" very slightly. Just enough that I have to turn the steering wheel left then right to keep in the lane. The push from the passing vehicle is v e r y slight, but it does require action on my part.
My wife drove the rig once and did not like the feeling, especially when large semis went by.
Is this something a sway control, like this https://www.etrailer.com/Weight-Distribution/Curt/17200.html would cure or eliminate? It's only 40 bucks US, considerably more in Cdn $ :o but I wonder if anyone here has experience with this.
Any advice is appreciated!
Thanks in advance.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Re: Sway Control - Will this help?
Postby hankaye » Sun May 06, 2018 11:04 pm
CoventryKid, Howdy;
Yup, that is a major reason most folks use them. Go over to flboy's thread
viewtopic.php?f=42&t=65498&start=1770
and see what he's got to say about how his handles.
I had one on a TT (Travel Trailer), different brand but same function, I used
to live and travel in and the difference was very noticeable.
hank
hankaye
Postby flboy » Sun May 06, 2018 11:24 pm
I am using two of those for the exact reason and crosswinds. They work well for me. One will work, but I am at the edge in weight limits for one, so I added another. The load balancing hitches will accomodate one or two sway bars.
You will still feel the draw when a big rig closes in, but I dont get the backlash from the trailer that I use to get.
The only negative IMHO is you need to disconnect them for backing up if you are going to turn at a sharp angle.
Other than that, it was all gain. Here are some pics of my setup.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby CoventryKid » Mon May 07, 2018 3:41 pm
Thanks Hank. Thank you Don. I'm going to order as soon as we get back to our base camp.
Cheers!
Doug
CoventryKid
Images: 130
Postby flboy » Mon May 07, 2018 5:11 pm
CoventryKid wrote:Thanks Hank. Thank you Don. I'm going to order as soon as we get back to our base camp.
Cheers!
If you happen to go by a Harbor Freight, the usually have them in the store for $29.99 made by Haul-Master. You need the Weight Distributing hitch as well which they also have there. Good luck! :thumbsup:
I am not sure about the ones you showed in the link, but beware of the self threading screws that come with the Harbor Freight sway bars . The bars themselves are fine, but the screws that come with them to "self thread" the pilot holes you drill into the frame are soft junk and will break or etc.. Just take one of them down to your hardware store as a "go by" and get some high quality stainless self threading of a very close size. You will be glad you did. I learned that one via the school of hard knocks. That must be where they save a few bucks.
Don (Flboy)
flboy
Images: 378
Postby CoventryKid » Mon May 07, 2018 10:52 pm
Thank again Don.
Amazon Canada has some incl Reese. Might be easiest for me.
Doug
CoventryKid
Images: 130
