Ducting around AC
Ducting around AC
Postby phoenixbound » Mon May 28, 2018 7:22 pm
Ready to place the AC. Looking for some ideas about how to duct around the AC exhaust. I know I need to isolate the exhaust from the AC, but I have a fair amount of space with an irregular space to cover. Any ideas? Insulation, insulation and tin, etc. ?
Smart enough to know that I still have a lot to learn.
Build diary at viewtopic.php?f=42&t=69652
phoenixbound
Re: Ducting around AC
Postby JRAnt74 » Mon May 28, 2018 7:36 pm
I would look thru Flboys thread at his a/c project. I believe he used the poly foam borad to seperate everything.
JRAnt74
Postby Joel.brian » Mon May 28, 2018 9:36 pm
Build it with wood and glue insulation to it
Joel.brian
Postby McDave » Mon May 28, 2018 11:03 pm
You should be able to use the polyiso foam. It's easy to work with and get snug fits, then tape and/or glue in place. You are just guiding and separating the intake and exhaust. You just don't want that air to mix with the cabin air that has been treated.
McDave
McDave
Images: 412
