Re: 7x17 Cargo Trailer Toy Hauler
Posted: Thu Nov 28, 2019 9:18 am
chiefvintage wrote:rebar wrote:Nice looking trailer!
Do you have any pictures of the frame at the axles? Did you remove any floor boards in that area?
I'm curious how much fab work would be required to narrow the axles
Haven’t done any mods to floor or frame, not needed for my application. The floor joists are 24” OC, and I’m installing 21” waste tanks to fit between the joists. This trailer could easily be lifted if needed using lift blocks between the axle mounts and frames, it has standard Dexter torsion axles.
Thanks. I lifted my old featherlite TH on blocks and remember it was a little scary working under a trailer with no axles. Narrowing wont be near as easy.
No need to remove the floor boards but if your under it, take a picture please.
