I have a very small seeping leak at the front wall that I cant find the source of. Any suggestions would be helpful. I have pulled all the the screws, put silicone in the holes and re-screwed them, but that didnt help. I just dont see where it would be coming in. It only manifests on the bottom right under the bend of the diamond plate, as pictured. It's pretty much all across...heavier on the left and right. I dont feel or see any other moisture on the wall. Only at this location. You can see a couple of seems across the front of the siding, but they overlap. I think it would be tough to get in there unless the rain was blowing up from the ground. The black channel on the left and right are well caulked, but then again, the moisture is across the entire front, so I would think it would have to be something high or central. Thoughts?
Sent from my SM-G960U using Tapatalk
