flboy wrote:.. a good small car electric radiator fan motor on a pulse width type variable speed control would rock if you can make that work. You'd have to engineer mounts and etc....
TimC wrote: Search "Case Fans" on tnttt and you'll likely come up with simple and complex uses...I use two 120mm case fans designed for computer cases. They each move about 33 CFM so in my teardrop I change the air once about every 3 or 4 minutes.
* Living in N. Texas, camping in Texas and Oklahoma, makes using A/C, 110vac fans (both off of parkpower or generator), and/or 12vdc-powerwd case fans very important. The usual temp range is 60f-110f, in March thru September.
* When I started building the trailer. I wanted to use heavy-duty hardware, industrial-look (trucking...I ran shipping/receiving depts, for years) parts, and perhaps re-purposed automotive parts (50+ years of automotive shade-tree mechanics, + 20+ years of drag racing...lotsa parts still lying around).
* I used rooftop vents (mounted on the sidewalls) from semi-trailers, and tried using some radiator fans for cooling, placed over the vents and one free-hanging. The vents worked great, but the radiator fans did not (in tests), much too loud/draw too many amps in such a small space (4x8 trailers are tight...), so I used a tabletop house fan mounted under the front shelf, and two 120mm computer case fans on swingaway mounts over the side vents. Mine only draw .18 ah, and push/pull 67 cfm.The 110vac main fan only uses 3 amps, so if I had to, I could use it via my inverter.
* And then there's the two awning windows, which I can use on cooler nights or in the rain; but using the A/C in 85f+ nights is normal for me.
- swingaway fans.jpg (202.36 KiB) Viewed 2179 times
- center-mount, under front shelf, 10 inch 110vac fan.jpg (237.76 KiB) Viewed 2179 times
