nose upper cabinet
nose upper cabinet
Postby yycwrangler » Fri May 21, 2021 8:01 am
Hi Folks
Doing the kitchen up in the front of my 6x12 vnose. My question is how do you support the upper cabinets from sagging, or for that matter collapsing during travel. My trailer is 5"9" wide and it seems like I should have a vertical strut in the middle to support the upper cabinet. But if I can avoid that middle strut would prefer
Cheers
Al
yycwrangler
Re: nose upper cabinet
Postby Modstock » Fri May 21, 2021 12:32 pm
Can you add a support inside the cabinet. Any pics?
Sent from my SM-A115AP using Tapatalk
Modstock
Postby kmack67.km » Sat May 22, 2021 8:18 am
Could you incorporate a beam across the bottom of the cabinets? Depending on how much weight you intend to put in them, you may be able to "hang" the ends of the beam on the walls using small joist hangers. The beam could be below the bottom edge of the cabinet or built into the front bottom edge of it.
Kevin
Sent from my SM-G950W using Tapatalk
kmack67.km
Postby hankaye » Sun May 23, 2021 8:00 am
yycwrangler, Howdy;
Have you explored a French Cleat type of system and then secure both
the 'support' cleat and the hanging bracket to the 'studs'.
hank
https://www.google.com/search?q=French+ ... e&ie=UTF-8
hankaye
