anyone with a reverse osmosis set up?
Postby onehoser » Thu Dec 09, 2021 1:33 pm
i bought a reverse osmosis system for my home and i thought it might be an good take one with us when we’re camping since we always seem to run low on drinking water and have to take a trip to nearest town. the pressure tank is a little large but i’m sure i can live without it, it won’t be plumbed into the trailer and i will only turn it on to make water as needed. i have a 45psi 12 volt pump that is enough to run the system. anyone else gone this route? any pro’s/cons?
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Re: anyone with a reverse osmosis set up?
Postby lfhoward » Thu Dec 09, 2021 3:21 pm
That’s a cool idea. I’m interested.
lfhoward
Postby Pmullen503 » Thu Dec 09, 2021 3:43 pm
What is your source of water to filter?
Pmullen503
Images: 67
Postby onehoser » Thu Dec 09, 2021 3:53 pm
Pmullen503 wrote:What is your source of water to filter?
i’d be using lake and stream water, and if we get rain i’ll use some of my tarps to catch it. i’d probably get more life out of the filters if i used rain water
onehoser
Postby featherliteCT1 » Thu Dec 09, 2021 6:55 pm
onehoser,
Sounds like a good idea.
Could you post a link to the unit you bought?
Thanks!
featherliteCT1
Postby onehoser » Thu Dec 09, 2021 7:12 pm
this is the unit i bought for the house, i’ll likely go with the same for the camper if it’s still available, that way i can use the same filters. i bought it at the canadian tire in ontario
onehoser
Postby Karebru » Fri Dec 10, 2021 1:37 am
Unless the way they operate has been improved, I'd think you'd need a substantial raw water supply.
The system we used to have at home produced several gallons of waste water for every gallon of usable filtered water.
If I remember correctly, everything runs through the pre-filters before much of it becomes "waste", so the waste water is at least, filtered.
Maybe store it separately for doing dishes, etc.? :thinking:
I'm not going outside until the temperature is above my age.
Karebru
Postby onehoser » Fri Dec 10, 2021 7:08 am
Karebru wrote:Unless the way they operate has been improved, I'd think you'd need a substantial raw water supply.
thanks for the heads up :) google search shows they are about 25% efficient, producing 4 gallons of waste water per gallon made. not too big of an issue since we mostly camp at lakes so rita can fish :) i wonder if there would be an issue with putting the waste water back through the system, i suffer with chronic laziness so the less water i have to carry, the better……
onehoser
Postby Pmullen503 » Fri Dec 10, 2021 8:44 am
If you are wanting to make drinking water from lake or river water, there are filters that make more sense and don't require constant source of power.
You could recycle your RO waste water but you'll still need power.
RO is best for removing chemicals from water, there are various filters for making water safe to drink biologically.
I use iodine tablets to make lake water safe to drink.
Pmullen503
Images: 67
Postby onehoser » Fri Dec 10, 2021 9:49 am
Pmullen503 wrote: I use iodine tablets to make lake water safe to drink.
we carry water purification tablets with us as plan B, for emergency use but haven’t had a need to use any of them…..yet :)
onehoser
Postby western traveler » Fri Dec 10, 2021 10:10 am
How much water are you needing at once?
I know some people like these. Just a lot less to tote around.
https://lifestraw.com/products/lifestra ... ravity-bag
western traveler
Images: 264
Postby onehoser » Thu Jan 06, 2022 8:46 am
western traveler wrote:How much water are you needing at once?
after doing a lot of research i decided to go with a ‘waterdrop’ water filter, far less work and cost than installing an RO system and it’s portable so i can use it with my 5x8, 6x12 and my off road expedition trailer Image
onehoser
