Scotch bowl
Scotch bowl
Postby sdakotadoug » Mon Sep 27, 2010 6:02 pm
Just picked up a Griswold Scotch bowl. I intent to use it mostly as a wok for stirfrying. Here's my question and showing my stupidity, how was the scotch bowl originally intended to be used?
sdakotadoug
Postby WarPony » Mon Sep 27, 2010 9:20 pm
Stupidity........... no, I'm going to say ignorance because I had never seen or heard of one of these, either. That thing is pretty cool!! I did a quick search and found some on Ebutt but nobody had any info. I'm guessing the ring has something to do with the name, I remember seeing a show that had some sort of Scotch pouring thing-a-ma-bobber with a ring on it.
Chili sounds good, let me know and I'll be over........ :lol:
Jeff
WarPony
Images: 289
Postby ironhead » Mon Sep 27, 2010 10:52 pm
There are a lot of uses for Scotch Bowls. Just be creative, for example you could cook soups, oatmeal, Etc, These were most often used for making a thick Scotch broth barley soup or for porridge.
ironhead
Postby d30gaijin » Tue Sep 28, 2010 9:38 pm
ironhead wrote:There are a lot of uses for Scotch Bowls. Just be creative, for example you could cook soups, oatmeal, Etc, These were most often used for making a thick Scotch broth barley soup or for porridge.
+1 what Ironhead said, for making broths and soups but also used for porridge, the latter more common to Maslin Kettles, I believe, but either can be used for both purposes based on my recent research on Maslin Kettles. They were not supplied with lids because what was typically cooked in them required frequent stirring.
Don
d30gaijin
Titanium Donating Member
Images: 139
Postby sdakotadoug » Tue Sep 28, 2010 11:19 pm
Thanks guys. Appreciate the information. My scoth bowl has just become more versitile. Doug
sdakotadoug
Postby sdakotadoug » Thu Dec 02, 2010 9:13 pm
Just checking this to see if my avitar uploaded
sdakotadoug
Re: Scotch bowl
Postby caseydog » Thu Dec 02, 2010 9:42 pm
sdakotadoug wrote:Just picked up a Griswold Scotch bowl. I intent to use it mostly as a wok for stirfrying. Here's my question and showing my stupidity, how was the scotch bowl originally intended to be used?
Drinking Scotch at a South Central Gathering? :thinking: :D
"These vessels were most often used for making thick Scotch broth barley soup or for porridge. The bowl is lidless because porridge has to be stirred constantly."
CD
My build journal is HERE
caseydog
Images: 515
Postby Dale M. » Thu Dec 02, 2010 10:43 pm
Dale M.
Images: 18
Postby SmokeyBob » Fri Dec 03, 2010 12:00 pm
Dale M. wrote:A little on Scotch Bowls...
http://ramblingsoncastiron.blogspot.com ... -bowl.html
Dale
Thanks for the link. Was woundering what a Scotch Bowl was.
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Postby greenturtle36 » Sat Dec 04, 2010 4:32 pm
Hi! thank you so much for referring to my blog. I also wondered what a scotch bowl was, and figured others would too.
greenturtle36
Postby cherokeegeorge » Sat Dec 04, 2010 6:45 pm
Great blog, thanks for the link :thumbsup: I've got a lot of reading to do.
George
For info on hitch covers
Teardrophitchcovers.com
cherokeegeorge
A Merkin Indian
Images: 37
Return to Cast Iron
