Aaron Coffee wrote:2 questions:
My DO has some spots that the seasoning seems to be coming off. How do I re-season it. Would it be better to remove the old seasoning and start from scratch? If so how? What my have caused this?
OK that was four questions. I thought I had read this info someplace but can't find it now.
Thanks
Hi Aaron,
I do quite a bit of DO cooking, but I don't always follow the "rules". I think most DO folks worry too much about seasoning. If you get a reasonably good base seasoning on the oven and cook regularly in it, the seasoning pretty well takes care of itself.
Here's my thoughts on the your particular oven.
I believe that most spotting comes from two causes. The oven wasn't really clean when it was seasoned. Or, the oil was put on too heavily and it didn't carbonize on the cast iron properly.
It the spotting isn't too bad, just keep cooking in the pot. Each time you are done cooking, clean it with hot water, heat it back up, and wipe it with a LIGHT coat of oil.
If the seasoning is coming off in large spots or if there are a lot of them, then you can throw the oven in the BBQ at full throttle for a couple of hours. This will normally burn off all the seasoning. Then go ahead and reseason.
That's my 02ยข worth.
Joanne
