Trying an indoor bread recipe!
Postby Dean in Ct. » Sat Jan 05, 2013 5:39 pm
Got a bread cookbook titled "Flour Water Salt Yeast" and all the bread recipes are cooked in a 4 qt. D.O. altho a 5 qt will also work, see pic!
Yeah, I've tasted and it's pretty good! The recipe would not adapt too well for camping, so I'll cook it at home!
Dean in Ct.
Images: 32
Re: Trying an indoor bread recipe!
Postby GerryS » Sat Jan 05, 2013 8:19 pm
Why not adaptable to camping? Bread has been baked long before our modern idea of what an oven is....
Ask Bob Henry...he's baked up some RIGHTIOUS bread at a few of our gatherings :)
GerryS
Postby KE5PPH » Sat Jan 05, 2013 10:37 pm
Everything tastes better cooked outside!
Mark
KE5PPH
Travel'n Gadget Show
04.5 LJ
KE5PPH
Postby Dean in Ct. » Sun Jan 06, 2013 7:51 am
The reason I think it would be difficult out in the open air is because it is a rather loose and sticky dough, with an overnight ferment, and I would have needed a lot of running H2O throughout the process! I'm sure wonderful breads are made while camping and I look forward to learning how to do it myself (with you alls help!), but maybe I'll start with a simpler recipe.
Dean in Ct.
Images: 32
Postby GerryS » Sun Jan 06, 2013 8:15 am
This similar to the 5 input artisan bread method?
I can see if lots of water is necessary where that could be problematic. I'm curious, could use a plastic bag instead of mixing bowls etc?
GerryS
Postby pmowers » Sun Jan 06, 2013 9:57 am
I have read through this book and it really is full of information. The author's idea is to use the dutch ovens to bake the loaves while trapping the steam inside. Besides the water, I think that a major stumbling block to using the method "in the wilds" is that the dutch ovens are preheated and baked in at 500 degrees.
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby GerryS » Sun Jan 06, 2013 10:17 am
Yeh,that's a little hot. A 20/10 briquette arrangement will give approximately 450 degrees on a 10 inch DO....the artisan bread book we have bakes at 425. We used a DO once, but it burned - maybe parchment paper would solve that problem...
Fr as cheap as wheat, salt, yeast and water is, I'd try it.....
GerryS
Postby wagondude » Sun Jan 06, 2013 11:09 am
Yeast can be frozen/refrigerated to make it last longer, but must be brought to ambient temp before you try to use it. Excessive heat will kill it. Storing in a galley would be ok as long as you are in a cool area where the galley temp would not get too high (just don't know off the top of my head what that temp is).
Bill
101137
wagondude
Images: 35
Postby KE5PPH » Sun Jan 06, 2013 2:29 pm
As Seen at Wallyworld. Taste of the South, magazine. Jan/Feb issue, it's their Annual cast iron edition. Tasty looking dishes, but all done" Indoors". Didn't see anything that wouldn't work out on a cook table. :R
Bummer that cookbook is out of stock.... :(
Mark
KE5PPH
04.5 LJ
KE5PPH
Postby bobhenry » Mon Jan 07, 2013 9:14 am
OK ......
I am gonna spill the beans.....
It's frozen bread right out of the freezer at Krogers....
6 bricketts under 18 on top ...
If it plumps up tight to the lid place a layer of foil on top of the well buttered top before cooking.( shiney side up to help keep from burning the top).
I seperate it and braid it for looks and just let it rise before baking.
While it may not be artisan bread , I never have to contend with leftovers after the pot luck dinners 'cause It's all Gone ! :shock:
9000 Club
9000 Club
Images: 2318
Postby Mike B » Tue Jan 08, 2013 9:40 am
biziedizie wrote:Now I just have to find a dutch oven, I've never seen one before but I'm sure I'll find one.
They are all over. I now have three indoor ovens and 6 camp ovens. Here is one of the indoor ovens:
It does a great job on potato bread, doesn't it? :)
Mike
Hayden Lake, ID
Mike B
Postby bobhenry » Tue Jan 08, 2013 1:27 pm
http://allrecipes.com/customrecipe/56136906/crusty-potato-bread/detail.aspx
I read elsewhere that if you find the addition of prepared instant potato flakes objectionable
simply bake up a nice sized baked potato to well baked ( soft) peel and mash with a fork and add in leiu of the flakes.
If you want something a little sweeter here is a great treat even for breakfast
http://allrecipes.com/Recipe/Grannys-Sweet-Potato-Bread/Detail.aspx?prop24=RD_RelatedRecipes
9000 Club
9000 Club
Images: 2318
Postby Corwin C » Thu Jan 10, 2013 6:25 pm
biziedizie wrote:So the secret is out :thumbsup:
Now I just have to find a dutch oven, I've never seen one before but I'm sure I'll find one :goodmorning:
Hardware stores are good places to look if you want new ... many of mine are from ACE hardware. If you don't mind used, yard/estate sales and goodwill stores are the best sources for me.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Return to Cast Iron
