MY new Duth Oven Heat Shield
Re: MY new Duth Oven Heat Shield
Postby mkitchen » Wed Mar 20, 2013 9:57 pm
I got mine from a junk yard here in town. They usually want a couple of dollars each but if you are buying 10 or so like I did you can dicker a bit on the price. No restrictions on getting plates here.
Stacie, I really like the idea of getting plates as you travel through different states. Each one would have a bit more meaning then. I tried to get as many different plates as I could but the choice was limited. I may have to expand my collection during my upcoming trips.
I have also found that a spring steel binder clip works great to connect the plates in a circle.
Mikey
mkitchen
Postby Verna » Thu Mar 21, 2013 6:08 am
Stacie, there are a lot of Indiana plates out there because we are issued new ones every 3 or 4 years. I once gave about 20 of the to a young boy who wanted his ceiling to be covered with license plates. Now I only have enough for my heat shield for my galley table.
I know most antique stores in Indiana have a few of the older plates.
Good luck
Verna
Indianapolis, IN
Verna
Images: 49
Postby deleted » Fri Mar 22, 2013 8:22 am
Thanks for all of the suggestions!
It will be no hardship to check out some thrift/antique stores on the trip. If I don't find them there I'll go online and try to find them from the states I traveled through on Goodwill and Ebay.
deleted
Images: 85
Postby campmaster-k » Fri Apr 12, 2013 11:19 am
Phooey wrote:In California it is apparently illegal to recycle/reuse license plates. I got a real lecture when I went to a pick and pull junkyard to see what I could come up with. So I decided to poke around on the internet. I scored a whole bundle of them off of Goodwill.com for just a few bucks. The site auctions stuff just like e-bay.
:thumbsup: :D
I just see it now. Cops rolling into the Dam Gathering just before dinner. Over the bullhorn - "Ok folks this is a bust. We know you have illegal plates around those ovens. We are going to have to confiscate all the Dutch Ovens and you are all going to jail." And just behind him a line of police with napkins tucked around their necks holding spoons and forks. :cry:
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby Phooey » Sat Apr 13, 2013 4:56 pm
Campmaster-K, thanks for the visual, I laughed until I cried. :applause: :applause: :applause:
Phooey
Postby deleted » Thu Apr 18, 2013 2:16 am
Image But probably not far from the truth!
deleted
Images: 85
Postby nevadatear » Fri Apr 19, 2013 12:01 am
Caryn, the coppers will have us in cuffs right behind you too. Will they let us take our cooking to jail? :)
Owner,Desert Metal Products. Custom machine shop. Inventory of thousands of bearings and seals, from the common to the archaic.
nevadatear
Images: 145
Postby bobhenry » Fri Apr 19, 2013 10:55 am
9000 Club
9000 Club
Images: 2323
Postby Phooey » Fri Apr 19, 2013 12:09 pm
Debbie, at least we will be in good company. Do you know how to make donuts? Oops, my bad. :o
Phooey
Postby slowcowboy » Fri Apr 19, 2013 8:46 pm
forget cali. come to wyoming in august at walk the winds. where its all legal and no one is going to scream in the comon sense state!
slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby rmclarke » Mon Apr 29, 2013 4:14 pm
***Deleted bad idea***....back to the drawing board :oops: :oops:
rmclarke
Images: 219
Postby Corwin C » Mon Apr 29, 2013 8:28 pm
Looks like it will work well, excellent idea.
Remember to be careful with heat and galvanized metal. If it gets too hot, the galvanization will make TOXIC smoke.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby rmclarke » Mon Apr 29, 2013 11:38 pm
Hmm...toxic smoke, not good.... :thinking: ....what if I heat it up really hot a couple of times before I use it ....would that 'burn' the bad stuff away??
rmclarke
Images: 219
Postby rmclarke » Mon Apr 29, 2013 11:45 pm
:shock: :shock: :o :oops: Wow...after doing a little research about galvanized metal I think I'm going to start over!!!
Thanks, Corwin for the headsup! I'll go back to the alum flashing idea.
rmclarke
Images: 219
Postby Corwin C » Tue Apr 30, 2013 10:12 pm
It takes quite a bit of heat. You will be okay if you use them for windbreak but keep them 3" - 4" away from the coals, more if the coals are really hot. The first sign of too much heat is a chalky white or yellow residue.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Return to Cast Iron
