Page 2 of 2
Re: MY new Duth Oven Heat Shield
PostPosted: Fri Mar 22, 2013 8:22 am
by deleted
Thanks for all of the suggestions!
It will be no hardship to check out some thrift/antique stores on the trip. If I don't find them there I'll go online and try to find them from the states I traveled through on Goodwill and Ebay.
PostPosted: Fri Apr 12, 2013 11:19 am
by campmaster-k
Phooey wrote:In California it is apparently illegal to recycle/reuse license plates. I got a real lecture when I went to a pick and pull junkyard to see what I could come up with. So I decided to poke around on the internet. I scored a whole bundle of them off of Goodwill.com for just a few bucks. The site auctions stuff just like e-bay.
:thumbsup: :D
I just see it now. Cops rolling into the Dam Gathering just before dinner. Over the bullhorn - "Ok folks this is a bust. We know you have illegal plates around those ovens. We are going to have to confiscate all the Dutch Ovens and you are all going to jail." And just behind him a line of police with napkins tucked around their necks holding spoons and forks. :cry:
PostPosted: Sat Apr 13, 2013 4:56 pm
by Phooey
Campmaster-K, thanks for the visual, I laughed until I cried. :applause: :applause: :applause:
PostPosted: Thu Apr 18, 2013 2:16 am
by deleted
Image But probably not far from the truth!
PostPosted: Fri Apr 19, 2013 12:01 am
by nevadatear
Caryn, the coppers will have us in cuffs right behind you too. Will they let us take our cooking to jail? :)
PostPosted: Fri Apr 19, 2013 10:55 am
by bobhenry
PostPosted: Fri Apr 19, 2013 12:09 pm
by Phooey
Debbie, at least we will be in good company. Do you know how to make donuts? Oops, my bad. :o
PostPosted: Mon Apr 29, 2013 4:14 pm
by rmclarke
***Deleted bad idea***....back to the drawing board :oops: :oops:
PostPosted: Mon Apr 29, 2013 8:28 pm
by Corwin C
Looks like it will work well, excellent idea.
Remember to be careful with heat and galvanized metal. If it gets too hot, the galvanization will make TOXIC smoke.
PostPosted: Mon Apr 29, 2013 11:38 pm
by rmclarke
Hmm...toxic smoke, not good.... :thinking: ....what if I heat it up really hot a couple of times before I use it ....would that 'burn' the bad stuff away??
PostPosted: Mon Apr 29, 2013 11:45 pm
by rmclarke
:shock: :shock: :o :oops: Wow...after doing a little research about galvanized metal I think I'm going to start over!!!
Thanks, Corwin for the headsup! I'll go back to the alum flashing idea.
PostPosted: Tue Apr 30, 2013 10:12 pm
by Corwin C
It takes quite a bit of heat. You will be okay if you use them for windbreak but keep them 3" - 4" away from the coals, more if the coals are really hot. The first sign of too much heat is a chalky white or yellow residue.
PostPosted: Thu May 30, 2013 2:08 am
by mkitchen
I think you will be ok with the plates. All of mine are aluminum, not galvinized and I have not seen any discoloration since I have been using them.
Mikey
